MBCruise
May 26, 2019Tutor
XR500 - MAC Wireless login to Routerlogin.net
Hi, I cant log in to the routerlogin.net via my wireless macbook. It used to work, but now I cant login to the XR500 and the devices connected to the router. If I use an old Macbook with ethernet ca...
- May 26, 2019
MBCruise wrote:I cant log in to the routerlogin.net via my wireless macbook
Whatever that means - not getting the browser-side login prompt for username & password, username or password not recognized, or the UI not loading, ...?
Any kind of DNSCrypt on that wireless Macbook?
What-if using the default gateway LAN IP (the router LAN IP address) in the browser?
Using the Guest instead of the "normal" wireless?
MBCruise
May 26, 2019Tutor
Hi, suddenly worked when switching to guest network :-), thx a lot
