blackbit7
Nov 23, 2018Aspirant
XR500 - PS4 Connection better with ISPs modem/router then XR500
Hello, my PS4 is connect via ethernet to my XR500. However when I put my modem the ISP provides into bridge mode and use the XR500 ethernet to my PS4 my connection seems slower. Speedtests through th...
- Nov 24, 2018
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Netduma_Jack
Nov 24, 2018NetDuma Partner
Hi there,
First of all, worth just clarifying the word 'speed'. Speeds can mean your bandwidth speed (how much data you can download or upload a second). But it can also mean your ping, which in gaming, is how fast your data is sent from you to the game's host (and then back again).
I don't think setting the modem to bridge mode would have affected your ping in game. But there's certainly quite a lot you can to give you better hit reg etc. Follow both of these guides and you should be all setup to get the best CoD connection:
Geo-Filter Optimal Settings: http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
QoS Optimal Settings: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
- blackbit7Nov 24, 2018Aspirant
I can't use geo filter because i'm playing competitive and we have to connect to whoever is hosting. I have QoS set up but notice 0 difference. I for sure get a higher in game ping and lower registration with using the XR500 then compared to just using my ISPs modem/router. I have no idea why I have tried everything I can think of. If I ask my ISP for a wired modem can that make a difference? The only thing I notice the XR500 does really well if when your on WiFi even gaming is good. But ethernet from XR500 or using ISP Modem/router the ISP wins by far in real world gaming. I'm generally confused.
