meridian_05
May 30, 2020Aspirant
XR500 - PS4 Wifi speed issues
Based in the UK. XR500 as router, Virgin Media v3 hub set as modem to M350 fibre broadband (362Mbps down). I purchased the router to get the most out of the M350 fibre plan, and for nearly all d...
Faulko
PS4 wifi performance is woeful at best, avoid using it at all cost.
Naturally cable is better but id take EoP over PS4 wifi any day.
Its not the router i can assure you of that.
