meridian_05
May 30, 2020Aspirant
XR500 - PS4 Wifi speed issues
Based in the UK. XR500 as router, Virgin Media v3 hub set as modem to M350 fibre broadband (362Mbps down). I purchased the router to get the most out of the M350 fibre plan, and for nearly all d...
Netduma-Fraser
May 30, 2020NetDuma Partner
The console speed tests can be inaccurate so I wouldn't pay too much attention to it, I have the same ISP/plan as you and I've not got full speeds through it with either router. Can you connect via ethernet with the PS4?
meridian_05
Console speed tests might be inaccurate compared to other speed tests, but this is comparing the console speed test on the v3 hub against the same console speed test on the XR500. Even when sitting the console next to the XR500 the speeds are often less that 1Mbps.
Disregarding the speed tests themselves, the wifi connection between PS4 and XR500 makes the PS4 unusable - unable to download at speed, unable to connect to games using chat, etc. It's so bad that I've had to revert back to using the v3 hub just to be able to play games.
- Netduma-FraserMay 30, 2020NetDuma PartnerAre you using the Geo-Filter? You'll need to add your friends to the allow list before you can chat with them. It also may be why the speeds are slowed if it's forced to use a different server.
