jirskyr
Dec 28, 2019Tutor
XR500 - VLAN tagging making wifi devices unable to communicate?
Hi, I'm in Australia and just joined NBN FTTC, which required a new router that supported VLAN tagging - got XR500. My ISP iinet requires VLAN tagging for their service, via VLAN ID 2. Internet k...
Netduma-Fraser
Dec 28, 2019NetDuma Partner
If you edit the standard rule and change the ID to 2 does that work at all? Are you able as a test to wire the shield to the router and see if it can connect to the NAS then just to rule out other issues.
