jirskyr
Dec 28, 2019Tutor
XR500 - VLAN tagging making wifi devices unable to communicate?
Hi, I'm in Australia and just joined NBN FTTC, which required a new router that supported VLAN tagging - got XR500. My ISP iinet requires VLAN tagging for their service, via VLAN ID 2. Internet k...
TypicalAardvark
Oct 16, 2020Guide
Yes I've tried the new beta, no it doesn't seem to make any difference.
Reudig
Oct 16, 2020Aspirant
Wow, that was quick!
Thank you.
So I'm going to buy another router then ...
Any suggestions?
OP mentioned he got an Asus RT-AC88U ... looks ok from what I can tell.
- TypicalAardvarkOct 16, 2020Guide
Our office shut down due to COVID so I never sourced a replacement router. But I haven't come across this problem on other routers, so hopefully you'll be fine with whatever you get.
- Netduma-FraserOct 17, 2020NetDuma PartnerTry it yourself but if it isn't working then let us know on the beta forum so the devs can look into it further.
- JamesBondxDOct 17, 2020Aspirant
Pretty sure it was tested above with no avail. Would be great if you guys could fix the VLAN and also add more options to add more DHCP serves for the VLAN's as well. Would make the router perfect for me and wouldn't have to swap it for something else.
- Netduma-FraserOct 17, 2020NetDuma PartnerEveryones connection is different so give it a go if you haven't, reset after the update to prevent legacy issues carrying over.
- b0byOct 17, 2020Aspirant
Receive today... and go back to Amazon after discover that issue...
last BETA update doesnt work.
- Netduma-FraserOct 17, 2020NetDuma Partnericeway_zhang please could you look into this?
- b0byOct 17, 2020AspirantPour faire plus simple, je parle en français.
J'ai un synology, une shield, un pont hue en ethernet, et le reste est en sans fil.
Je suis chez orange en opérateur, le xr500 est directement compatible avec eux.. À ce que il paraît.
J'ai passé l'après midi dessus... Impossible depuis le WiFi d'atteindre mon serveur plex hébergé sur mon syno depuis une page Web. Ping OK pourtant...
Multiple RaZ et puis j'ai découvert que ya du monde depuis 1an qui galère avec ce problème...
La version proposé par Fraser n'arrange pas le souci.
Bref, mauvaise expérience mais vite rétabli en le remettant dans la boîte et en utilisant la box opérateur..
