mattrichards
Mar 16, 2020Guide
XR500 - Voip phone not connecting
Hi all, I have a xr500 which is working well with pretty much out of the box config. My wife is now work from home and was instructed to bring her voip phone (Polycom VVX400) home. All her cowork...
- Mar 16, 2020
Thanks for the response. The issue is resolved... I checked and she had used the wrong port on the phone. Apologies for the false alarm!
Mar 16, 2020Guru - Experienced User
What modem are you using?
Did they send a power supply with the Polycom VVX400? It has the option of PoE but the XR500 doesn't have PoE so the Polycom VVX400 needs a power source.
mattrichards
Mar 16, 2020Guide
