Blind_Joe
Jun 05, 2023Aspirant
XR500 - wake on wan not working.
Hello. I can't deal with wake on WAN not working and it seems to me that the netgear router is the cause. Wake on LAN is working properly so the computer configuration is correct. I have a static I...
Netduma-Fraser
Jun 05, 2023NetDuma Partner
Does the XR have a direct path to the internet? I.e. is the XR in the DMZ of your modem/router or are you using a pure modem?
- Blind_JoeJun 05, 2023Aspirant
My router has an internal wan IP address given by the fiber modem. I do not know if dmz active, for sure the operator informed me that all ports are open / redirected to my router.
- Netduma-FraserJun 05, 2023NetDuma PartnerDo you yourself have the ability to access the ISP modem/router to check?
I don't have that option. I can ask isp how it is set up
