Blind_Joe
Jun 05, 2023Aspirant
XR500 - wake on wan not working.
Hello. I can't deal with wake on WAN not working and it seems to me that the netgear router is the cause. Wake on LAN is working properly so the computer configuration is correct. I have a static I...
Blind_Joe
My router has an internal wan IP address given by the fiber modem. I do not know if dmz active, for sure the operator informed me that all ports are open / redirected to my router.
Netduma-Fraser
Jun 05, 2023NetDuma Partner
Do you yourself have the ability to access the ISP modem/router to check?
- Blind_JoeJun 05, 2023Aspirant
I don't have that option. I can ask isp how it is set up
- Netduma-FraserJun 05, 2023NetDuma PartnerIt would be good to double check how it's set so that you can be sure it's nothing on that side causing it.
- Blind_JoeJun 12, 2023Aspirant
My isp says they made dmz
