karothacker
Jan 30, 2018Guide
XR500 - What settings are needed to have Open NAT on 2 Xbox One Consoles?
Hi, I just purchased the XR500 (Router) and the CM1000 (Modem) to replace my current setup because it was outdated and giving me "Strict NAT" issues with both my Xbox One Systems. It was 4+ years old...
karothacker
Jan 30, 2018Guide
Thank you for your quick reply.
So I was just need to assign different ports to different consoles? Does it matter if they are both on WiFi and not hard wired?
Netduma-Fraser
Jan 30, 2018NetDuma Partner
Only if they both don't get an open NAT immediately and I would recommend giving them a port on the consoles settings yes. That doesn't matter but they would have a better connection if wired.
