FriendOfJah
Apr 10, 2020Tutor
XR500 - WiFi Calling Stopped Working?
Hi Folks, I recently bought a new NetGear CM1150V Cable Modem and XR500 Nighthawk Router to replace my XFinity Cable Modem/Router as I was having major problems using my iPhone's (AT&T) in my hom...
Koz1614
May 01, 2020Tutor
Any update on this? I recently upgraded all my networking equipment (CM1150v modem, XR500 router, EX7700 Extender). I was using WIFI calling today connected to the EX7700 and the call dropped off WIFI calling mid conversation. The call did not drop, however I saw on the iphone that the 'Sprint - Wi-Fi' was gone and only the wifi symbol showed. I rely heavily on wifi calling as well since service in my area is not great. Any update/suggestions?
Netduma-Fraser
May 01, 2020NetDuma Partner
I don't have any suggestions at the moment unfortunately but this is something we're looking into right now actually, if we can find the cause and there is a setting change that can be made to resolve it until a fix is available I will let you know.
- Koz1614May 01, 2020Tutor
Netduma-Fraser Thanks for the reply. Unrelated to the wifi calling, I had one other issue today. Woke up this morning and everything was working great - phone and mac were blazing fast. About 30 min later, my father tried to connect his work computer to the XR500 - was not able to connect. I restarted my mac (which was just connected and working great)...upon restart I was not able to conect to either the EX7700 or XR500. During this time, my iphone was still working great..so I restarted the iphone - same issue..could no longer connect. It seemed like something was blocking the new/restarted devices from connecting? The internet was connected because as I stated devices were working fine until they were restarted. A full reboot of the router solved the problem for now. Any settings I should look for if this happens again?
- Netduma-FraserMay 02, 2020NetDuma PartnerI assume you have nothing setup in Content Filtering? Were you able to check if the EX had internet - if you plugged into it? If you set Static/reserved IPs for the devices in LAN Settings do you see this behavior again?
- Koz1614May 02, 2020Tutor
No, I have not had a chance to play with any of the features yet..just set up the XR500 on Thursday. So right now its a factory out of the box setup. EX7700 had internet at the time, but as I said it was not just the extender that I was not able to connect to. Tried going directly to the XR500 and still no luck. I guess I could try to static everything but I dont think I should have to do that...
