FriendOfJah
Apr 10, 2020Tutor
XR500 - WiFi Calling Stopped Working?
Hi Folks, I recently bought a new NetGear CM1150V Cable Modem and XR500 Nighthawk Router to replace my XFinity Cable Modem/Router as I was having major problems using my iPhone's (AT&T) in my hom...
May 26, 2020Guru - Experienced User
Be sure beamforming is enabled. Smart Connect can be enabled or try with out SC enabled.
Check your ISP modem for buit in router here. Not recommended having built in router at the modem.
Netduma-Fraser
May 26, 2020NetDuma Partner
I'm pretty sure we've fixed this on our end in 3.0. Sign up to the beta here so you can help us test it when available: http://www.netgearinnovation.com/dumaos-beta/index.html
