X_BEOX
Apr 23, 2020Guide
XR500 & AC1900 wifi channels
Hello. I am trying to improve performance at home. I have a XR500 as my main router and an AC1900 as a range extender/repeater. The XR500 is connected to my PC via wired connection and I use the DUMA...
Apr 23, 2020Guru - Experienced User
Review the AC1900s user manual for setup and installation information.
Netduma-Fraser
Apr 23, 2020NetDuma Partner
You would have to connect direct to the AC or enable remote management on it if possible. I would suggest choosing different channels also.
- X_BEOXApr 26, 2020Guide
I connected to the AC1900 but the selections for channel are grayed out. I can't see a way to change them. Any ideas?
- Netduma-FraserApr 26, 2020NetDuma PartnerHow is the AC setup? Is it using a Smart Connect type feature?
- X_BEOXJun 11, 2020Guide
I replaced both devices. A few weeks apart but yeah. Throwing more money at a problem. I am a dope.
