trvshady
May 13, 2022Follower
XR500 + CGM4140COM from Xfinity - Disconnects internet every 5-10 minutes then comes back.
My firmware is up to date and both the XR500 router and the Xfinity modem are brand new. Not sure why but the internet will cut out every 5-10 minutes although the internet light stays on on the rout...
Netduma-Fraser
May 13, 2022NetDuma Partner
In LAN Settings set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
