psykixx
Jul 07, 2018Star
XR500 & EX8000
So.. I got totally cheesed off trying to get a reliable ethernet backhaul working with my Orbi system and returned it.
I purchased an XR500 and a EX8000 which I use as an AP. All working great ...
Anonymous
Jul 24, 2018Netduma_Jack Can you add fixing google play services not being accessible when the XR500 and nighthawk extenders EX8000/EX7800 are in mesh mode?
Netduma-Fraser
Jul 25, 2018NetDuma Partner
Its only not accessible when in that state? What about when connecting direct to the XR500, does it work properly then?
- AnonymousJul 25, 2018
Netduma-Fraser That's correct. Even if I connect to the SSID of the XR500 by being closest to it and connecting with a full strength signal vs the EX8000/7800 I am unable to access google play services. With the XR500 as a stand alone it works. Mesh, it doesn't work. Also as a test I've tried using the EX8000/7800 as an Access Point with a wired connection to the XR500, it breaks google play services again. This happens if I connect to the SSID of the XR500 or the EX8000/7800 running in AP mode. There is something the XR500 does not like about having those extenders connected to it in any mode.
- Netduma-FraserJul 25, 2018NetDuma PartnerInteresting thanks we'll look into it. If you change DNS on the XR500 does it work then?
Netduma-Fraser Funny you ask that. I was using OpenDNS and thought it was the problem and I may have had things too restrictive so I swapped over to my ISPs DNS servers and that didn't work either. I believe I've even used Googles DNS servers as well with the same result. But if you put those two devices in a mesh and use any android device, you will not be able to even access the play store. I've seen at least one other person in the forums with this issue so I know it's not just a one off.
