5m5me
Aug 02, 2019Follower
XR500 & Samsung Powerbot SR20M7070WS
Hello, I’ve changed my modem and router a little while ago and I’ve not been successful in connecting these devices to work (XR500 being the issue as I’ve done an isolation test) but I can work out ho...
Aug 02, 2019Guru - Experienced User
Is Smart Connect enabled? Try disabling Smart Connect.
Netduma-Fraser
Aug 06, 2019NetDuma Partner
As above it is most likely to be smart connect, disable that and connect it manually to the 2.4GHz network. If that doesn't work try enabling guest WiFi and connecting it to that instead.
