tClancey
Jan 24, 2019Tutor
xr500 + sky router + double nat
PLEASE NOTE, XR500, not C7000. I can't find xr500 in the list.
A friend asked if I could help setup his new router, he has no laptop or pc, he's only just got used to using and phone. In the ...
Netduma-Fraser
Jan 24, 2019NetDuma Partner
The above is great advice. Also you may need to use DHCP Option 61 for Sky in Internet Setup.
tClancey
Jan 26, 2019Tutor
As far as I'm aware the ER115 doesn't have a bridge mode, or modem only mode, it just isn't there.
Sky do not give out login details so he can't use another modem. Why he's so keen to use sky I have no idea, I'd sooner spit in my own ear, but each to their own!
So that leaves the 2nd option. Which is perfectly possible for him to setup through his xbox. But I'm a little confused, how does setting a DMZ ip address get arround the double nat? Surely each box is still doing the same as it was??
- Netduma-FraserJan 26, 2019NetDuma PartnerDMZ sends all ports to the device you put in it so it's sort of like a modem mode. So best advice would be put the router in it's DMZ then disable the Sky WiFi to ensure no devices connect to it. The XR500 has to control all devices to be used effectively.
- tClanceyJan 26, 2019Tutor
He's just called to sky to see how they would help, who said, "Yes, now our policy allows people to use the routers and modems of choice."
So he asked, "Can I have my internet credentials please?"
The reply was, "Sorry we don't give out that information."
So, sky are in breach of their own policy, and still make it impossible for you to use your own router/modem. This is beyond stupidity.
Does anyone out there know how we can get this information? Otherwise he's just spent £500 on publicly a available home router which his ISP is actively preventing him from using.
Is this even legal?
Thanks Fraser, in the mean time I will get him to give this a go. But the whole situation is beyond belief. I've advised him to kick sky in the balls and find someone else. I find forcing someone into their data collection practices distasteful to say the least.
