tcookes
Jul 19, 2018Tutor
XR500 & Sonos
Hi All!
I have just upgraded my Router to the XR500 Nighthawk Gaming Router.
The only major barrier I have come up against is the connection to my collection of Sonos wireless speakers (S...
Killhippie
Jul 20, 2018Prodigy
I have a B&W Zeppelin Wireless and a Sony HTNT5 soundbar, both connect just fine. There is no reason Sonos should not connect. I would follow Frasers advice, also use 2.4Ghz not 5Ghz as wireless speakers dont need much bandwidth and 2.4Ghz travels much further. If you have recent upgraded firmware and this continues may I suggest a factory rest and set up again, not using a backup, as that may cure your issue too.
- tcookesJul 20, 2018Tutor
Thanks both for the suggestions.
Turned off the smart connect and created separate names for the two bands. Tried setup on the 2.4ghz channel however same issue as last time. Comes up on LAN but falls over on WiFi.
Also did factory reset, and setup router from scratch. Again came to the same failed screen on sonos app.
Any other suggestions??
- Netduma-FraserJul 20, 2018NetDuma PartnerI have a few ideas, untick IGMP Proxying in WAN Setup and disable SIP ALG. It may also be that SONOS does not support beamforming and mu-mimo so I would experiment with disabling these in Settings > Advanced Settings > Advanced Wireless.
This guide from Sonos may also be worth trying: https://support.sonos.com/s/article/1219?language=en_US as well as the suggestion at the bottom of this page: https://support.sonos.com/s/article/290?language=en_US#panel2-1- KillhippieJul 21, 2018Prodigy
Sadly it may be a case of the router does not support Sonos equipment. The R7800 is not supprted and since the XR500 uses the same SoC, switch etc and apart from the extra Flash (NAND) at 256MB compared with the R7800's 128 Flash (NAND) It's identicle even down to the same 512MB DDR3 RAM so I would imagine its not supported too. Looking at the supported routers or unsupported is the better bet as there are quite a few as even BT's Whole Home Mesh routers has issues with Sonos, so I would say buying a router known to be supported by Sonos is the best bet really.
https://en.community.sonos.com/troubleshooting-228999/netgear-r7800-x4s-nighthawk-confirmed-incompatible-with-sonos-6803875
