tcookes
Jul 19, 2018Tutor
XR500 & Sonos
Hi All!
I have just upgraded my Router to the XR500 Nighthawk Gaming Router.
The only major barrier I have come up against is the connection to my collection of Sonos wireless speakers (S...
vanderboegh
Jul 23, 2018Tutor
We have 5 Sonos speakers in our home and we are also using the xr500 with zero issues. I would try the wireless setup in the sonos app under advanced settings.
tcookes
Jul 23, 2018Tutor
Hi Vanderboegh,
Very interesting! A few questions on this.
1. Did it just work straight away for you? Or any particular settings you had to change?
2. Did you previously have your sonos setup with another router?
3. And to confirm, you're using the speakers wirelessly correct? As I could get it work when plugged into the LAN... just not wirelessly
4. You have the original 'Sonos Play:1' speakers? Or the newer model 'Sonos One'?
Appreciate any further pointers you can give. As I was about to give up with this router!
Thanks
- W1lliamJul 24, 2018Virtuoso
Try to configure your 2.4GHz channel on XR500 as fixed CH1/6/11, Settings->Wireless Setup->Wireless Network (2.4GHz b/g/n)->Channel
Also try to change Mode between "Up to 54Mbps", "Up to 347Mbps" and "Up to 800Mbps".
Seems Sonos has interoperability on this 2.4GHz channels for its data rate and bandwidth. Above is try to figure out what might be wrong for XR500 with Sonos, once identified the root cause, more easier to come out proper solution.
William
