Kushy58
Mar 04, 2018Apprentice
XR500 & X10 Comparison
Hi there I have upgraded from sky fibre to sky fibre pro and don’t like the sky q router, I’m looking at the XR500 and the X10 routers to swap with, I already have a new openreach modem but may swap ...
- Mar 16, 2018It sounds like what I mentioned before, I don't think this will cause you any issues. If you're concerned I would recommend calling Netgear support as they should be able to help.
Netduma-Fraser
Mar 23, 2018NetDuma Partner
Hi Kushy, thanks for the update and sorry you're having this issue. Please upgrade to the latest firmware (it contains bug fixes) and hopefully the issue will not happen again: https://kb.netgear.com/000055519/XR500-Firmware-Version-2-2-1-10
Kushy58
Mar 23, 2018Apprentice
I had already done that last night
- Netduma-FraserMar 23, 2018NetDuma PartnerOkay no worries, keep any eye on it and let us know if it happens again
