Kushy58
Mar 04, 2018Apprentice
XR500 & X10 Comparison
Hi there I have upgraded from sky fibre to sky fibre pro and don’t like the sky q router, I’m looking at the XR500 and the X10 routers to swap with, I already have a new openreach modem but may swap ...
- Mar 16, 2018It sounds like what I mentioned before, I don't think this will cause you any issues. If you're concerned I would recommend calling Netgear support as they should be able to help.
Kushy58
Mar 23, 2018Apprentice
I had already done that last night
Netduma-Fraser
Mar 23, 2018NetDuma Partner
Okay no worries, keep any eye on it and let us know if it happens again
