Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
Hi Everyone,
I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
XRaptor29
May 13, 2018Luminary
Just a heads up, latest Alpha build for the Xbox One has addressed this issue according to the change log. Hopefully it'll fix the problem when it leaves the insider program.
They've also fixed the WiFi issue on the Xbox disconnecting from the internet when the console was on Instant On mode.
- Osiris_BlackMay 13, 2018Star
XRaptor29, I guess I will just have to wait and see.
- Osiris_BlackMay 15, 2018Star
Netduma-Fraser Update: My Xbox One is disconnected on start-up from the Internet while Instant-on mode was disabled, so this was not the fix we were hoping for.
Again, stating from above:
- Lights are normally flashing on router
- Xbox will reconnect after router is rebooted.
- Xbox is hardwired and is one of the two hardwired that are affected (PS4 hardwired also, is disconnected)
- Everything connected wirelessly is working fine.
- QoS, IPV6, and UPNP are active.
- Netduma-FraserMay 16, 2018NetDuma PartnerThanks for the update. The Xbox Team and the Netgear Team are in active communication regarding this issue and seem to be aware of what the cause may be. Would you be able to provide me with your Xbox version please?
