Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
Hi Everyone,
I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
Aug 28, 2018Guru - Experienced User
Does this happen with both wired or wireless connections at the xbox?
What FW version is currently loaded?
cment77 wrote:
I'm having the same issue and wondering if the end result was a network card issue with the Xbox One X?
cment77
Aug 28, 2018Tutor
Yes both wired and wireless. Although if I connect using wireless the span of days is longer that I stay connected than when the Xbox is wired in. So for example if the Xbox is wired to the XR500 then after 2 days it will be disconnected but if connected wirelessly then 5 or 7 days.
