Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
Hi Everyone,
I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
Aug 28, 2018Guru - Experienced User
I would make contact with MS support and ask about this. Let then know what you have, what you tried, both connections and that other devices work with this router. MS should and needs to review this.
Curious, has Instant ON feature been disabled on the game consoles?
Netduma-Fraser
Aug 29, 2018NetDuma Partner
If instant on is disabled and automatic updates are disabled then it should resolve the issue. We're in touch with the Xbox team regarding a fix for this.
- FURRYe38Aug 29, 2018Guru - Experienced User
Good ol Instant ON back at it again. :smileyfrustrated:
- B1ggSh00t3rSep 03, 2018Apprentice
I have no issues with my Xbox One X or Xbox One S using the 'Instant On' setting. Both are wired (connection).
