Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
 Hi Everyone,
 I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
NupeEsq
Sep 28, 2018Tutor
This thread has been very helpful. Unforutnately, neither the new Netgear firmware nor the latest Xbox firmware has addressed the issue. I'm having the same problem. Connected via LAN things work fine; then I turn it off into Instant On mode, and when you wake it up, Xbox says it can't connect. Moreover, the router says its disconnected in the Device Manger tab on DumaOS. Hope there is a fix for this soon. Does anyone have any advice? Thanks!
XRaptor29
Sep 28, 2018Luminary
This is actually affecting more routers than the XR500. Friend of mine doesn't have the XR500 and has this issue. It's a Xbox side problem.
