Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
 Hi Everyone,
 I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
Netduma-Fraser
Oct 05, 2018NetDuma Partner
Hi Raptor, do you have links to other sites that indicate its an issue on other routers as well?
XRaptor29
Oct 05, 2018Luminary
Friend of mine that has the Xbox One X  doesn't have the XR500 and has this issue.
Also Google searching : xbox one x disconnecting from internet after instant on will bring up a lot of links revolving around this issue.
- FURRYe38Oct 05, 2018Guru - Experienced User
Instant ON has reared its ugly head again. I recommend users turn this feature off if they see issues with there xbox. This isn't the first time Instant ON has caused problems. :smileymad:
 - B1ggSh00t3rOct 05, 2018ApprenticeI’ve had NO issues w/ ‘Instant On’ enabled on my Xbox One X.
 - Netduma-FraserOct 08, 2018NetDuma PartnerGreat thanks Raptor, I'll pass this on to the team looking at this and that will hopefully point them in the right direction.
