brianharvey1
Jul 12, 2021Aspirant
xr500 + xr1000 cant connect ps4 to ps5
i have a xr500 upstairs connected to a ps4 a xr1000 downstairs connected to a ps5. ps4 + ps5 have nat type2. xr500 has hybrid vpn xr1000 no vpn. can connect to voice chat on psn (after switching f...
brianharvey1
Jul 17, 2021Aspirant
hi.
yes i am seeing a moderate/strict NAT in game when geo-filter is on but can conect when geo-fiter is off.
now the geo-filter is not showing anything on spectator mod or filter mode(xr500) tryed removing ps4 from netgear router flushing cloud restart nothing.
this os is one of the worst i have seen spent hours online loking for sulotions but nothing works for me.
geo-filter works then dose not with no changes i have spent over £500 on these routers for a gaming setup for filtiring.
i am at an end with this.
brianharvey1
ok so i have now factory reset xr500 set up dmz for ps4 and ps5 is the same on xr1000.
now the geo-filter is working.
when i connect ps4 to ps5 in party chat with geo-filter in spectator mod it connects then i allow the players on the allow list no problems.
when geo-filter is on filter mod i get cannot perform voice chat due to network failure even though it shows the ps4 as allowed?
this is all before i start a game.
- Netduma-FraserJul 17, 2021NetDuma PartnerThere will be something blocked on the map when it doesn't work, whatever that is allow it and it will work
- brianharvey1Jul 17, 2021Aspirant
ok i can now connect to voice chat with filter mode on.
this is the problem i am having when in game i cannot connect ps4xr500 to ps5xr1000
still get connection error nat type may be to strict?
nat 2 on ps4 and ps5.
any ideas on how i can change nat type through the routers to get nat1?
- Netduma-FraserJul 17, 2021NetDuma PartnerAre you trying to connect the two routers together to play on the same team or against each other? Impossible to get NAT 1 unless you're connected direct to the modem - NAT type 2 is fine. I'd recommend you put the XR1000 in AP mode and then all devices connected to it will appear as though they are connected to the 500 and can be controlled by it
