brianharvey1
Jul 12, 2021Aspirant
xr500 + xr1000 cant connect ps4 to ps5
i have a xr500 upstairs connected to a ps4 a xr1000 downstairs connected to a ps5. ps4 + ps5 have nat type2. xr500 has hybrid vpn xr1000 no vpn. can connect to voice chat on psn (after switching f...
Netduma-Fraser
Jul 17, 2021NetDuma Partner
There will be something blocked on the map when it doesn't work, whatever that is allow it and it will work
brianharvey1
Jul 17, 2021Aspirant
ok i can now connect to voice chat with filter mode on.
this is the problem i am having when in game i cannot connect ps4xr500 to ps5xr1000
still get connection error nat type may be to strict?
nat 2 on ps4 and ps5.
any ideas on how i can change nat type through the routers to get nat1?
- Netduma-FraserJul 17, 2021NetDuma PartnerAre you trying to connect the two routers together to play on the same team or against each other? Impossible to get NAT 1 unless you're connected direct to the modem - NAT type 2 is fine. I'd recommend you put the XR1000 in AP mode and then all devices connected to it will appear as though they are connected to the 500 and can be controlled by it
- brianharvey1Jul 23, 2021Aspirant
i can now connect the ps5 to the ps4 in game on the same team.
but have to have ping set to 10ms but because of that any other players can join.
what i am trying to do is get me ps5 an 2 friends on my team my son ps4 and 2 of his friends on his team and play against each other.
this is on destiny2 in glory pvp but cant match against each other due to having to set ping assist on which matches us against random teams.
any help?
- Netduma-FraserJul 23, 2021NetDuma PartnerYou can't match against each other using the router, that's not the purpose of the router, there may be other methods out there to help you do that
