Permanentsingle
Oct 29, 2019Tutor
XR500, 2 Playstation Pros, Destiny 2 Woes
Receiving an intermittant error code Baboon via Destiny 2 when teaming up with another person on my local network. Disconnects only occur when teaming up. Wanted to make sure it was not my current...
- Oct 29, 2019This may be a port conflict then. Take the one PS4 out of the DMZ and just leave UPnP on. Reboot the consoles and router and then try again.
Netduma-Fraser
Oct 29, 2019NetDuma Partner
When does the disconnect occur? When you've tried to search for a game together or at the moment of connecting to each other for example. Are you using the Geo-Filter? If so make sure that strict mode is disabled.
Permanentsingle
Oct 29, 2019Tutor
Thanks for the fast reply. :smileyhappy:
Occurs when gaming together on the same team only. No disconnects when we are seperately grouped or solo in game.
Disconnect is intermittant. Sometimes when searching for a game while grouped, other times disconnection occurs mid game session - only when grouped.
Geo-Filter is turned off
- Netduma-FraserOct 29, 2019NetDuma PartnerThis may be a port conflict then. Take the one PS4 out of the DMZ and just leave UPnP on. Reboot the consoles and router and then try again.
- PermanentsingleOct 29, 2019Tutor
Will do. I'll report my findings later tonight.
Much appreciated.
