Permanentsingle
Oct 29, 2019Tutor
XR500, 2 Playstation Pros, Destiny 2 Woes
Receiving an intermittant error code Baboon via Destiny 2 when teaming up with another person on my local network. Disconnects only occur when teaming up. Wanted to make sure it was not my current...
- Oct 29, 2019This may be a port conflict then. Take the one PS4 out of the DMZ and just leave UPnP on. Reboot the consoles and router and then try again.
Permanentsingle
Oct 29, 2019Tutor
Thanks for the fast reply. :smileyhappy:
When does the disconnect occur?
Occurs when gaming together on the same team only. No disconnects when we are seperately grouped or solo in game.
When you've tried to search for a game together or at the moment of connecting to each other for example
Disconnect is intermittant. Sometimes when searching for a game while grouped, other times disconnection occurs mid game session - only when grouped.
Are you using the Geo-Filter? If so make sure that strict mode is disabled.
Geo-Filter is turned off
Netduma-Fraser
Oct 29, 2019NetDuma Partner
- PermanentsingleOct 29, 2019Tutor
Will do. I'll report my findings later tonight.
Much appreciated.
