blackshirt40
Dec 17, 2019Guide
Xr500 5g band completely disappears
Is there a newer beta firmware I can try? Ever since the last stable firmware was pushed out I have had really inconsistent wifi issues with the bands dropping randomly or just really poor performance...
Netduma-Fraser
Dec 17, 2019NetDuma Partner
There isn't unfortunately. Are you using Smart Connect? If you disable this does it work any better when manually connecting to 5GHz?
