Daniel5243
Nov 13, 2019Aspirant
XR500 5GHz channel not showing up in Device Manager
Hi, I have devices that are connected to my 5 GHz channel, but they (and the channel) are not showing up in the Device manager. I'm using firmware version V2.3.2.56 I made an unlisted YouTu...
BmoreBateman
Nov 14, 2019Guide
This is the same exact issue I am seeing. everything works great and then after a 1-3 days, the 5GHz channel just stops and dies. then the the 2.4GHz is extremely slow
- Netduma-FraserNov 14, 2019NetDuma Partner
Here's a suggestion I've just thought of for both of you, could you setup a guest 5GHz network and see if the same issues exist on that please?
It also may be worth checking out some of the suggestions in this topic from Bateman and seeing if they work for you at all. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-Wifi-Slows-to-a-crawl/m-p/1824392#M14700- Daniel5243Nov 17, 2019Aspirant
Hi,
I setup the Guest 5 GHz channel and after a few days I am still able to connect to it and it appears in device manager. However the regular 5 GHz channel is still not displaying.Daniel Lee
- Netduma-FraserNov 19, 2019NetDuma PartnerBateman managed to resolve his issue so have a look at his solution and see if it works for you: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-Wifi-Slows-to-a-crawl/m-p/1825714#M14784
