G4Captain
Jun 27, 2020Star
XR500 5ghz Connection Problem
I have a brand new MSI GE66 with the Killer AX1650i. It connects to the 2.4ghz band no problem. It sees the 5ghz band, attempts to connect, but says it is unable to connect to that network. I have bo...
Netduma-Fraser
Jun 27, 2020NetDuma Partner
When you try to connect to 5GHz does it connect with no internet or completely refuse to connect to the WiFi? Do you have any manual settings setup for the WiFi adapter?
- G4CaptainJun 27, 2020Star
It attempts to connect and then says it is unable to connect to that network. The only settings I changed were the names of the networks.
- Netduma-FraserJun 28, 2020NetDuma PartnerIf you factory reset the router, leaving the WiFi names default but disabling Smart Connect does it allow you to connect then? Don't change anything else before you try.
- G4CaptainJun 28, 2020Star
I think I figured out the issue that was preventing it from connecting. The MU-MIMO setting was turned off. When I turned that back on, it connects now no problem. I don't know why it wouldn't connect with that off, but it seems to be fixed now.
Thanks.
