Tylerp95
Sep 04, 2020Follower
XR500 AC Adapter replacement
Hi there, does anyone know where I can buy a XR500 adapter or an adapter that's compatible? (UK)
I think one of the pins is bent or broken in mine and the router isn't getting any power.
1 Reply
- Netduma-FraserNetDuma PartnerI don't think there are any official replacement adapters you can buy that I am aware of. I would recommend taking a look at the voltage and getting one that is the same with the same output and it will work just fine.
