Rogue8448
Jul 27, 2019Aspirant
XR500 Advanced Traffic Prioritization
Was trying to set up traffic prioritization for Rainbow Six Siege on this, So I go to advanced and add Port 6016 to the source port and destination port and its still not picking up the packets.
Netduma-Fraser
Jul 28, 2019NetDuma Partner
Are you playing this on PC? Do not change the source port just the destination. Leave the source port as the default range it gives you and it will work. If you're using console there is no need to add manual ports.
- Rogue8448Jul 28, 2019Aspirant
Yes im playing on PC. And set it up like you said -
UDP - Source Port (1:65535) - Destination Port (6015:6015)
And its still not detecting any high priority traffic when im playing siege.
- Netduma-FraserJul 28, 2019NetDuma PartnerMake sure you add the uPlay ports as well, does it work then?
Did that and only one starts detecting traffic is port 443 which i hope would detect traffic sinces its the port for http which alot of programs use.
