Rogue8448
Jul 27, 2019Aspirant
XR500 Advanced Traffic Prioritization
Was trying to set up traffic prioritization for Rainbow Six Siege on this, So I go to advanced and add Port 6016 to the source port and destination port and its still not picking up the packets.
Rogue8448
Jul 28, 2019Aspirant
Added those ports and still nothing. When I added port 443 last (since i knew it was just http) it spiked then closed the game and it was still going.
Rogue8448
Reached out to ubi support to see if they could give me some more insight on which ports may be needed
- Netduma-FraserJul 28, 2019NetDuma PartnerOkay let us know if the ports they provide work as once the correct ports are added there is no reason why it wouldn't work.
- Rogue8448Jul 28, 2019Aspirant
They just responded and said the specific ports used by rainbow six siege are: UDP 10000-10099, 3074, 6015. Ran those ports into it and still not picking it up. Guess it just doesnt work with siege right now and hopefully in the future it may end up working. Just would be nice to cut down on any latency for such a competetive shooter.
- Netduma-FraserJul 28, 2019NetDuma PartnerThere is no reason why it shouldn't work if the correct ports are used. Is it definitely the correct device that you have picked? Double check the IP in the device manager with the IP on the PC itself and make sure it's showing as online in the device manager. If that's all correct I would suggest running a program called Wireshark when you're playing and see if any other ports may be being used then you could add those.
