Spandex
Mar 09, 2023Tutor
XR500 After Hard Reset Cannot Access Rules In Traffic Controller
On the right hand side on traffic analytics all the settings still show even though on the left there is nothing because the xr500 has been factory reset and there should be nothing there, so i tried...
Netduma-Fraser
Mar 10, 2023NetDuma Partner
Could you make an account on forum.netduma.com and then let me know your username? Then I can add you to the beta so you can see if it's still an issue on that firmware.
Spandex
Mar 11, 2023Tutor
Sure, if you get what i mean the traffic controller section that was added is fantastic and was so useful but it seems to me that when it was done someone forgot to test it after the router had been factory reset, like i said i found another thread by a woman with exactly this problem as well, it is rare that someone would need to factory reset and i think this is why this problem cropped up and was not tested properly.
