Oblius
Dec 29, 2020Aspirant
XR500 after one year it stop doing his main fuction of preventing lag
Nobody else had my same issue? with this firmware(V2.3.2.66) everything is **bleep**ed up??? I can't play a game that I start lag again if somebody is downloading or playing league of legends. This ...
Dec 29, 2020Guru - Experienced User
What modem/gateway do you have?
Is it only 1 game? a certain devices?
Have you tried factory resetting and reinstalling?
Have you tried installing the DumaOS 3.0 beta firmware?
There's many members on here with DumaOS devices that still work well.
I don't have one so I can't speak of their performance or how to optimize them but there's members several on here who are.
Such as Netduma_Alex Netduma-Fraser
there's even guides.
- plemansDec 29, 2020Guru - Experienced UserMight also do better in the proper forum.
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers - ObliusDec 29, 2020Aspirant
I'll try what you said starting from the beta.
I know that I upgraded at the last update e the biggest function stop working.
Now I try the beta that I didn't know it existed,than I'll try to reset. I'll keep you update,if you don't hear me next days probably I solved.
See ya- Netduma-FraserDec 29, 2020NetDuma PartnerOkay great, good luck! Hope to not hear from you in the best possible way :)
- ObliusFeb 12, 2021Aspirant
Still nothing, I did all the try. I understand is a new product with new things. But I bought it and after a year I started lagging again that was the only reason I bought it :/ pretty sure there a lot others like me.
