Oblius
Dec 29, 2020Aspirant
XR500 after one year it stop doing his main fuction of preventing lag
Nobody else had my same issue? with this firmware(V2.3.2.66) everything is **bleep**ed up??? I can't play a game that I start lag again if somebody is downloading or playing league of legends. This ...
Oblius
I'll try what you said starting from the beta.
I know that I upgraded at the last update e the biggest function stop working.
Now I try the beta that I didn't know it existed,than I'll try to reset. I'll keep you update,if you don't hear me next days probably I solved.
See ya
Netduma-Fraser
Dec 29, 2020NetDuma Partner
Okay great, good luck! Hope to not hear from you in the best possible way :)
- ObliusFeb 12, 2021Aspirant
Still nothing, I did all the try. I understand is a new product with new things. But I bought it and after a year I started lagging again that was the only reason I bought it :/ pretty sure there a lot others like me.
- Netduma-FraserFeb 12, 2021NetDuma PartnerTry this one as it's the very latest and has fixes in: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0 make sure to reset afterwards.
