z0nk
Sep 20, 2020Star
XR500 afterwarranty service
Hello, I'm looking for afterwarranty service for XR500 device - uboot is broken, device is working in switch mode, only usb2 led is lighting. Where can I find list services that will be able to rep...
Netduma-Fraser
Sep 22, 2020NetDuma Partner
How did that happen? Your best bet is to use TFTP to try and upload the latest firmware and see if that resolves it https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
z0nk
Sep 22, 2020Star
I don't know (power light is not blinking)- there's no response on serial port (previously it was) = no hope for tftp
engineers designd this device very well - it has broken just after warranty. No after warranty service = when it's broken, there's no chance to save our planet from electroscrap.
For 1 year I was happy customer but now, I will avoid to purshase device s from Netgear - better to go for unbranded device for less than half price.
- Netduma-FraserSep 22, 2020NetDuma PartnerHave you tried the TFTP method at all?
- mardock2009Jan 13, 2021Guide
hi
after reboot router
i have same problem only usb2 ligt on and light from connected ethernet cable .... router not booting no power light
try power off for 5 min and transfer image via tftp but not response from tftp ant help please ?
- Netduma-FraserJan 13, 2021NetDuma Partnermardock2009 a reboot caused this issue? How did you reboot it? Can you access the interface?
