ep2015
Jul 24, 2019Apprentice
XR500: All devices suddenly loose the ability to download, but can still upload
I'd like to know if anyone else has had this issue. All my connected devices lose the ability to download, but the DumaOS panel shows they are still uploading (blue bar graph instead of red). I o...
Jul 24, 2019Guru - Experienced User
Have your ISP check the singal and quality of there service up to the modem. Have them check there logs to see if they see any thing on there side when this happens on the modem.
ep2015
Jul 25, 2019Apprentice
Another quick update and then this topic can be closed.
I lost internet connection again on the modem twice this morning, so I had the modem swapped out. One of the lights on the modem, which was a dark blue before, is now cyan, which is a good thing. So far so good, but I do not believe the router is at fault here - it just seems to report "uploading" on devices when there is no connection available. Maybe it's a bug, but it's probably too rare or out-of-sight for anyone to notice.
Thanks for all the help.
- Netduma-FraserJul 25, 2019NetDuma PartnerGreat to hear that, thank you very much for the update!
