HunterHarden
Jul 11, 2019Tutor
XR500 Allow/Deny
I recently bought an XR500 and I’ve got some questions about the GeoFilter with Allow/Deny. Pretty much my situation is i want to connect with a friend in Indiana but I’m in Washington and I don’t ...
HunterHarden
Jul 11, 2019Tutor
Also!! Can someone please explain strict mode on geofilter settings?? :?
- Netduma-FraserJul 11, 2019NetDuma PartnerThis will explain how to use allow/deny to add a friend: http://support.netduma.com/en/support/solutions/articles/16000089132-how-to-use-allow-and-deny-on-dumaos
Strict mode ensure servers are within your radius, with it off it would allow servers outside the radius. It was primarily introduced for Destiny so unless you're playing that I would recommend you keep it enabled.- HunterHardenJul 11, 2019TutorI’m actually playing Destiny 2! If I set the geofilter radius and turn off strict mode, will I be connected to people outside the radius through those servers?
- Netduma-FraserJul 13, 2019NetDuma PartnerOkay in that case do disable strict mode. You may notice some servers being allowed outside your radius, this is necessary for you to sustain a connection while in game. You might get connected to players outside the radius if they're connecting through the server but as you should be closer to the server you'll have the advantage.
