JonSnowKnowsNad
Jan 16, 2020Apprentice
XR500 An error has occurred (E-82221407) PS4 Party Chat
An error has occurred (E-82221407) PS4 Party Chat. I can't use ps4 party chat. Speed tests show my internet has more than enough bandwidth. What may be causing this and what can I do to solve this p...
Netduma-Fraser
Jan 16, 2020NetDuma Partner
Are you using the Geo-Filter when you encounter this issue? If so have you added your friends to your allow list? If not you'll need to do that. If you have do you see anything blocked on the map? If you do you'll need to allow this as well and that should work. Then could you give us the ID of that server please and we can add it to our whitelist.
JonSnowKnowsNad
i wasnt using geo filter. i think i find what was wrong. i disabled bridge mode and i think that caused some of those problems. would that most likely be the reason. after i enabled bridge mode on my isp modem everything seemed to work. the geo-filter i think if i put it in spectating mode, party chat always works, but when it's in filtered mode it doesn't work. even if i allow all the servers outside. it's also very inconvenient because i've had this issue before and putting the geo filter in spectating mode just makes ps4 party chat more viable.
- Netduma-FraserJan 16, 2020NetDuma PartnerSo does it work with the Geo-Filter in Filtering mode and without bridge mode? If so then put the XR router WAN IP in the ISP hub DMZ instead to avoid a double NAT.
- JonSnowKnowsNadJan 16, 2020Apprentice
it doesnt work with out bridge mode or its finnicky at least
- Netduma-FraserJan 16, 2020NetDuma PartnerSo there are absolutely no servers or icons being blocked when the Geo-Filter is in Filtering Mode with the map fully zoomed out when you try to join/are in a party chat?
