Telebubbies
Feb 08, 2020Aspirant
XR500 and 2 gbps?
Hey guys. I got a XR500 and my current internet speed is 100mbps. In a few weeks, I should be able to have access to 1gbps download and 600mbps upload. Right now, I have my default ISP router connect...
Netduma-Fraser
Feb 08, 2020NetDuma Partner
The XR500 only supports gigabit WAN so you would not be able to achieve more than 1gbps. If you want to have higher than 1gbps WAN then you could opt for the XR700 instead which allows this.
- TelebubbiesFeb 08, 2020Aspirant
Hi. Thanks for the reply. I just found out that I will actually be able to get 10gbps. Are there any netduma routers with 10g WAN? What's the maximum on the xr700?
Thanks
- Netduma-FraserFeb 08, 2020NetDuma PartnerThe XR700 is the only one that could support 10g WAN, you can find out some more information here: https://kb.netgear.com/000060606/How-do-I-set-up-my-10G-SFP-port-for-WAN-on-my-NETGEAR-Nighthawk-XR700-Pro-Gaming-Router
