jeremyg237
Apr 09, 2018Luminary
XR500 and bandwidth alocation
I used to own the NEDUMA R1 and when I was single the bandwith alocation was no big deal. But now with a wife and kiddo it is a little chaotic. I suggest doing a system like the R7000. Low, med and h...
Netduma-Fraser
Apr 09, 2018NetDuma Partner
Very good points, thank you for the feedback. I think we will be doing something with this in future.
For Traffic Prioritization you could disable DumaOS Classified Games and just add your Xbox instead instead of your Son's. Though gaming does not require much bandwidth so you could easily have them both prioritized with no downsides.
jeremyg237
When I had the r7000 I had us both on low and they worked fine.
- Netduma-FraserApr 10, 2018NetDuma PartnerThat's great but high priority is better to ensure the best connection, both can be done at the same time.
