Gidgriff
Jun 09, 2021Guide
XR500 and BT Fibre 900 FFTP
Hi all, Reading through the forums and online it looks like there is a common fault with the XR500 with them being capped to 550mb/s. I have spoken to BT and they have confirmed im getting 935mb...
Netduma-Liam
Jun 11, 2021NetDuma Partner
Are you not able to configure PPPoE settings on the BT Hub like you have done on the XR?
Gidgriff
Jun 16, 2021Guide
Hi guys, me again!
I gave up on the XR500 and bought a R8000 instead. I have never had so many issues trying to set up a router in my entire life. Tried setting up via the Nighthawk app like it tells me to, and even though im connected to the router via WIFI the app cant find the router. Tried it via ethernet, wont find the routerlogin page and just gives me an error that im not connected to the internet. I have tried clearing cache, didnt do anything. Any suggestions?
- Netduma-LiamJun 16, 2021NetDuma Partner
OK sorry to hear that, this forum is actually for support of DumaOS powered routers so we won't really be able to provide any advice on the R8000, perhaps consider creating a new topic at the below forum for support:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
