Gidgriff
Jun 09, 2021Guide
XR500 and BT Fibre 900 FFTP
Hi all, Reading through the forums and online it looks like there is a common fault with the XR500 with them being capped to 550mb/s. I have spoken to BT and they have confirmed im getting 935mb...
Netduma-Fraser
Jun 18, 2021NetDuma Partner
You would need to remove it manually, unless you have factory reset and running through the wizard the first time, which after reconnecting it again after awhile might be a good idea.
Gidgriff
Jun 18, 2021Guide
Not sure whats going on if im honest. I have turned the PPPoE settings off on my XR, its connected via the internet port to the Smart Hub 2, all blue lights on and wont even let me on the Router menu and says no internet connection. Even after a reset?
