Roxhound
Aug 09, 2019Tutor
XR500 and certain equipement wont work with it
Greetings, So i switched from a r8000 to the xr500. I like the DUMAOS, but it seems that certain things will not work thru it. DirecTV - Can get an IP, but cannot connect out to the world...
Netduma-Fraser
Aug 10, 2019NetDuma Partner
I think you will need to enable IGMP Proxying in the WAN Settings in order for these devices to work, if not let us know and we can try other steps.
- RoxhoundAug 10, 2019Tutor
Greetings,
Will try that, went out of town, but will try tomorrow and see if that solves the problem.
Hope it works...
- RoxhoundAug 11, 2019Tutor
Greetings,
Well that didnt work, a no go....
Next idea?
have like 4 days till i gotta take it back..... really dont want to.....
- RoxhoundAug 12, 2019Tutor
Bump.....
Running out of time before i take it back....
- Netduma-FraserAug 13, 2019NetDuma PartnerWhat is your exact physical setup e.g. modem > XR500 and how is have you connected the ISP hub to the XR500, is the hub in modem mode, are you using the DMZ?
