Roxhound
Aug 09, 2019Tutor
XR500 and certain equipement wont work with it
Greetings, So i switched from a r8000 to the xr500. I like the DUMAOS, but it seems that certain things will not work thru it. DirecTV - Can get an IP, but cannot connect out to the world...
Netduma-Fraser
Aug 10, 2019NetDuma Partner
I think you will need to enable IGMP Proxying in the WAN Settings in order for these devices to work, if not let us know and we can try other steps.
Roxhound
Aug 12, 2019Tutor
Bump.....
Running out of time before i take it back....
- Netduma-FraserAug 13, 2019NetDuma PartnerWhat is your exact physical setup e.g. modem > XR500 and how is have you connected the ISP hub to the XR500, is the hub in modem mode, are you using the DMZ?
