Roxhound
Aug 09, 2019Tutor
XR500 and certain equipement wont work with it
Greetings, So i switched from a r8000 to the xr500. I like the DUMAOS, but it seems that certain things will not work thru it. DirecTV - Can get an IP, but cannot connect out to the world...
Roxhound
Aug 12, 2019Tutor
Bump.....
Running out of time before i take it back....
Netduma-Fraser
Aug 13, 2019NetDuma Partner
What is your exact physical setup e.g. modem > XR500 and how is have you connected the ISP hub to the XR500, is the hub in modem mode, are you using the DMZ?
